ModelCHECK ASM Scope Results Table
I wrote a sample custom ModelCHECK check that runs in the assembly scope (_ASM). I have populated the results table but when the results are displayed I only see results for the top-level assembly. My check function was called multiple times (I ran at "All Levels") so I know it was called for multiple components in the assembly. So my quesion is how do I properly populate the results table in an assembly scope check? I noticed (through the debugger) that each time my check function was called I got a new memory location for the results table pointer.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995(business)
+1 520.545.6399(fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
This
