ModelCHECK Interactive in Creo 8.0 is very slow
in Creo 2 M250 I was using ModelCHECK Interactive with real satisfaction. Now after switching to Creo 8.0.0.0 or 8.0.0.2, ModelCHECK Interactive has become at least 15 times slower.
I did the test on a very simple prt and using the same settings.
While bypassing my personal configuration and using the default ModelCHECK configuration, the operation is still very slow ...
Can someone help me?
Thank you.
Mahesh_Sharma
22-Sapphire I
@bmancini
You my try the same on default part without any geometry and share the comparison results.
Sometimes, geometry checks with complicated geometry leads such delay. If possible share some example data with config files.
Mahesh_Sharma
22-Sapphire I
@bmancini
bmancini15-MoonstoneAuthor
Thanks for the reply.
For now I have no way of doing tests, when I have, I will resume the topic, thanks.
