ModelCheck Layers
  • April 17, 2015
  • 3 replies
  • 1875 views
Afternoon all,
I am trying to configure ModelCheck to clean up my part layers.
Most features work as planned IE. Datum Planes, Curves, Points etc..
But Axis seems a little challenging.
My Layer.mcs file has these layers defined.
/Test 1
PRT_LAYER PRT_DTM_AXIS BLANK DATUM_AXIS
PRT_LAYER PRT_AXIS BLANK AXIS
Run MC and results are: manually created axis are layered off, feature
based axis (protrusions,cuts, holes etc..) are not layered.
Next step to test out the MC function, add these layer settings to my
Layers.mcs file.
/Test 2
PRT_LAYER PRT_HOLE BLANK HOLE
PRT_LAYER PRT_PROTRUSION BLANK PROTRUSION
Run MC and results are: Holes and Protrusions layered off, the actual
feature is still visible and the axis are off
So my questions is why doesn't the first test run grab the axis of features?
I do not want all the extra layers created, one layer called Prt_Axis that
contain all axis
Any tips would be appreciated
CREO elements Pro 5 M190
Jeff​
*Jeff Lippeth* *▪* *Mold Design Engineer*
*NyproMold, Inc.*955 Tri-State Parkway, Gurnee IL 60031
144 Pleasant St, Clinton MA 01510 *▪* www.nypromold.com
T 847.855.2226 *▪* F 847-855-2303
That's not just a ModelCheck limitation. If you used Layer Rules instead of ModelCheck you'd also have to make sure the rules gathered the features that contain axes.
Have you tried putting this in?
PRT_LAYER PRT_AXIS BLANK HOLE
PRT_LAYER PRT_AXIS BLANK PROTRUSION
If it works, it should create a single layer and put all axes, holes and protrusions on that layer.
In Reply to J Scott:
Afternoon all,
/Test 1
Layers.mcs file.
/Test 2
contain all axis
Jeff​
https://nypromold.adobeconnect.com/jlippeth-meeting/
*This e-mail may contain information which is confidential or privileged.
The information is intended to be for the use of the individual or entity
named above. If you are not the intended recipient, be aware that any
disclosure, copying, distribution or use of the contents of this e-mail is
prohibited. In the event of any error in transmission, unauthorized
recipients are requested to contact the sender immediately and not to
disclose or make use of this information. No employee or agent is
authorized to conclude any binding agreement on behalf of NyproMold with
another party by email without express written confirmation by NyproMold
Offices.*
P *Please consider the environmental impact of printing this e-mail*
jlippeth1-VisitorAuthor
Thanks Don
Your suggestion makes sense and did the trick.
So I guess i'll go update my question on PTC/Community
Ahh. I'm not subscribed to that one or I'd have put the answer there, too.
Thanks Don
Additional Creo Questions - PTC Community
Where it sits for 4 hours (19 views) (0 replies) ugh.
Have a Great weekend
Jeff
On Fri, Apr 17, 2015 at 12:55 PM, Don Senchuk
> that contain axes.
> Afternoon all,
> /Test 1
> Layers.mcs file.
> /Test 2
> features?
> contain all axis
> Jeff​
