11-Garnet
ModelCheck reporting no issues & not appearing in browser
I'm trying to configure modelcheck to add 2x parameters to every model in a large assembly.
I have model update set to Y, so model check is 'allowed' to modify the models to add params:
I have PARAMCHECK set to error:
And I have added parameters for it to check against:
But whenever I run the modelcheck regen or interactive, it reports 0 errors 0 warnings.
On that note, It's also appearing in the white box of the RHS of the screen but not in the in-built browser. I have used modelcheck in the grey/tan in-browser context before but have never seen that window/context appear on this computer, I've only ever had the white box.
I do have "Show Report" set to Y, which I thought would make it appear in the browser but it's not working.
Can anyone shed some light on this please? I don't fancy having to manually define the parameters in every single part/aseembly
Mahesh_Sharma
22-Sapphire I
@Fianna
Files are configured correctly as these files are working for me without any changes. I think you need to check conditions (conditions.mcc) as conditions might be missing these files. Review your condition.mcc or share
Mahesh_Sharma
22-Sapphire I
@Fianna
Can you share your ModelCHECK files?
Fianna11-GarnetAuthor
11-Garnet
Hi Mahesh,
Zip attached, It wouldn't accept mcs or mch file extensions as attachments here
Mahesh_Sharma
22-Sapphire I
@Fianna
