Modelling
I have some suppressed features in part model. I want to enable that suppressed features in assembly level. (Like simp rep). Is possible to do in part level simp rep? or other option.
But I don't want to create an instance.
kdirth
kdirthAnswer
You can use flexibility to turn on those features in the assembly.
Using Flexible Parts/Assemblies
tbraxton
One option would be to create a derivative part using merge/inheritance functionality to control part geometry explicitly in part mode. You can then swap out the components in a rep in assembly mode.
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/assembly/asm/About_Inheritance_Features.html#:~:text=Inheritance%20features%20allow%20one-way%20associative%20propagation%20of%20geometry,Inheritance%20features%20to%20create%20variations%20of%20existing%20models.
kdirth
kdirth21-Topaz IAnswer
