Moment of Inertia Along Length of Part
I understand well how to find the moment of inertia at a plane through my part, however, I would like to know if it is possible to find the moment of inertia (in one given direction) as a function of the distance along the part.  My main purpose for doing this is to find the location and value of the minimum moment of inertia.  It is a complex part so this cannot be done easily just by inspection.
Any help is greatly appreciated!
rcookAnswer
You can do this pretty easy with a user-defined analysis (UDA).
1. Create a curve along the geometry in the direction that you want to measure (sketch or copied composite curve) along the surface or centerline.
2. Put a field point on the curve.
3. Create a plane on the field point and normal to the curve.
4. Create a X-Section Mass Properties analysis based on the plane, save as a feature (make sure to select the parameter(s) you want to graph from the Feature tab).
5. Group the field point, plane, and analysis.
6. Run a UDA, select the group that you just created (probably selected already) and the parameter that you want to graph. You can change settings, export to Excel, save the analysis for later, etc. all from the UDA.
Roger
rcook1-VisitorAnswer
Roger
elangdale1-VisitorAuthor
I was able to do all of this until I found that I needed the Behavioral Modeler.  I will work on that.  Thanks for the help so far!  This seems like the correct method.
