Move felxable part form sub-assembly in top assembly
Hello all,
I have a flexible spring, it is attached to a housing assembly.  i am able to move the housing assembly and the spring changes shape as expected.  now what I cant figure out how to make work is, put the housing into a frame assembly.
make the part in such a way that places the spring in the housing under a certian compression, depending on the perameters of the frame
the tree is spring>housing>frame
spring is flexible, housing can be moved, but when the housing is in the frame assembly and i constrain it, the spring does not adjust automatically.
