Moving 'holes' in Creo elements 4 ?
I'm stuggling a bit to understand how to move things in Creo Elements.
I have designed a 'connect 4' style board, basically a flat plate with holes. I did this in 2d and then extruded the flat. However the cicles that formed the holes were not correctly aligned so I need to edit the position of the holes. The plate is a single 'part' as I understand it.
Could someone point me towards a tutorial or tell me how to do this ?
I like Creo and recommend it to our clients but I struggle to find appropriate how-to's at the moment.
Thanks in advance for your help.
