multi bend
hello all . i hadd plate ,i want to make 3 bends in differient positions.ihad made two but the last can not exexute till i delete the other bend >please help .see attached files
psobejkoAnswer
This sequence worked for me:
 11
22
3 - bend using "up to end of surface" option3 - bend using "up to end of surface" option
4 - add an extrusion to form a flat section that...4 - add an extrusion to form a flat section that...
 ... can be bent (again using the "to end of surface" option)... can be bent (again using the "to end of surface" option)It's definitely not intuitive...
2-Explorer
September 8, 2017
thanks friend.but after applying bend 1  and bend 3  the position of bend 2 is flat.look at pic belowbend 2-1.jpg
