Multiple radii with conic round option
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
Unable to add transitions or multiple radius values when using the D1 x D2 conic option.
    Mahesh_Sharma
    22-Sapphire I
    Hi @VM_10376400
    This is a known limitation of Creo Parametric. The behavior has been the same from early Creo Versions.
    Mahesh_Sharma
    22-Sapphire I
    Hi @VM_10376400
    Hi Mahesh, thank you for your response. Are there any known workarounds?
    Mahesh_Sharma
    22-Sapphire I
    Hi @VM_10376400
    There are no known workarounds as Conic D1xD2 is for constant round.
    Thanks.
