Need help with exporting 3 model
I need help with the following: In Creo, I want to export a rendered model as Graphics Language Transmission Format (glTF)
for use in an html page. In addition, the model must be loaded in fixed position in the html page after which the user can rotate the object etc. etc.. How do I do that from Creo so with a fixed position?
TreblaAnswer
Hi DS,
You could do the following:
From Creo Parametric, open your model, then 'Save as' to U3D format.
Second step transform to GLTF from some online converter, like this one
Trebla16-PearlAnswer
Hi DS,
