Sep 21, 2015 11:08 PM UTC
need to duplicate geometry of view(same like catia)
Please let me know how to duplicate(break link) with model in drawing
kdirth
Sep 22, 2015 8:10 PM UTC
If you are looking to turn the view into draft entities not dependent on the model, select the view and select Convert to Draft Group in the Edit group on the Layout tab.
Mahesh_Sharma
22-Sapphire I
Sep 22, 2015 9:16 PM UTC
Srinath,
If you would like to make the drawing independent, you can convert all views in drawing to draft group (Select all views > Convert to Draft group) and delete the part from drawing using Drawing Models > Del Model > Select the model to remove. This will make the drawing independent.
Mahesh_Sharma
22-Sapphire I
Sep 28, 2015 6:15 PM UTC
Hi Srinath,
Does any of the reply on post answer your query?
