Feb 24, 2023 10:37 PM UTC
Negative version level for product
Recently I notice a negative version level for product in common space. Not sure how this happened, does any body has a clue why this happened. I am using  Creo Parametric  Version 8.0.4.0
Thank you
TomU
TomUAnswer
Feb 25, 2023 1:21 PM UTC
While it may look like a negative number, it's actually not.  A version is comprised of the revision, a dot, and the iteration.  The revision series is configurable, but typically something like A, B, C, D, E,... or 1, 2, 3, 4, 5, ... is used.  It's pretty common to have the first revision in either series start with the dash ( - ).
See these help pages:
TomU
TomU23-Emerald IVAnswer
Feb 27, 2023 4:20 PM UTC
Thank you.
Feb 26, 2023 4:24 AM UTC
You can set each Windchill Product to start with either a "-" or a number for the revision scheme. You image is showing the version which is comprised of revision.iteration.
Version=revision.iteration
-.2
A.5
LL.21
Feb 27, 2023 4:19 PM UTC
Thank llie, my issue is that I changed the version level to 1 and checked the model to common space. The next day the model level is changed to -.1 and -.2
I like to know or found the root cause.
Thank you.
StephenW
Feb 27, 2023 4:25 PM UTC
Look at the history of the part in the commonspace to see what the History of the check-in and revision history is
