Network exported to Creo View
When saving a cabling assembly to Creo View, the network is saved with it, leading to a lot of green lines that sorta look like wires, confusing production. You can turn it off in Creo View by unchecking the "curves" filter, but our filters are set by default, so for those who don't know that, it's still annoying and confusing.
Has anyone had any luck in preventing the network from being exported to Creo View? Hiding it has no effect (as is usually the case with Creo View).
PetePickettII
i would like this option to not export the network into a PVZ file as well.
we are currently using creo 5 but moving to creo 8 soon.
