Networks, Wires and Cables, Oh My!
To all,
I am using CREO 3.0 M090.
When I route a cable or wire using a network everything is fine.
When I modicy the Wire I see that it says Simple Route.  It appears that it loose the connection to the network I used orignlaly to route the cable or wire.
Is there any way I can find out the name of the networks that was originally used to route the Cable or Wire?
Is there a config setting that I need to set?
Thanks for your help.
