Nov 17, 2011 5:37 PM UTC
No line where two surfaces meet
I got a problem with this. When there is an interference of two surfaces
pro/e does not print the interference line. For example when a dowel pin is
pressed into a hole on a surface. All you see is the round at the top of
the dowel pin not the round where it meets the surface.
Is there a way to turn this on? like show tan lines or surface line or
maybe setting annoying from yes to no.
I know where has to be a setting because some times it works.
Alfonso
amedina1-VisitorAuthor
Nov 17, 2011 5:54 PM UTC
That's really interesting. I gave it a search and there is no solution for
this.
Michael_Martin
Nov 18, 2011 3:28 PM UTC
PTC will say that is intended functionality. I say it is painful whan you have to publish drawings of some elses assemblycontaining press fits.
