Note color in pvz export
I have many users that use the Dark theme in Creo parametric 9. The note color is yellow for that theme. When exporting to a PVZ the text color is also yellow. How can I change that so they can keep the dark theme and export the note text to black or whatever preferred color?
I tried changing the the system_colors_file to C:\Program Files\PTC\Creo 9.0.3.0\Common Files\text\system_colors\light.scl but that did not resolve the issue.
Catalina
Community Manager
Hi @ZC_10909252,
Thank you for your question! I am replying to raise awareness. Hopefully, another community member will be able to help.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation!
Catalina | PTC Community Manager
