3-Newcomer
Offset automatic dimension points in sketch
Hello
I'm wondering if it's possible to change the dimension points that are automatically selected when starting a new 2d sketch on a part. That is, offsetting the given dimensions in a 2d sketch.
simple example:
I draw a rectangle on a profile in sketch mode and want to dimension it separately from the right and left sides.
If someone understands my concern and knows how to fix it, I would be happy about an answer.
Greetings
Rafael
Google translate
Translated by - Anurag Singh
Date - 03/28/2023
Hallo
Ich frage mich, ob man bei einer neuen 2d Skizze auf einem Bauteil, die Bemassungspunkte, die automatisch ausgewählt werden, ändern kann. Das heisst, versetzen der vorgegebenen Bemassungen in einer 2d-Skizze.
einfaches Beispiel:
Auf einem Profil zeichne ich im Skizziermodus ein Rechteck und möchte dies von der rechten und linken Seite einzeln bemassen.
Wenn jemand mein Anliegen versteht und weiss wie es zu beheben, wäre ich über eine Antwort froh.
Gruss Rafael
Michael
In Creo Parametric, when you start a 2D sketch and create a rectangle, the software typically selects default points for dimensioning, usually based on the sketch's origin or reference points. However, you have the flexibility to modify these dimensions and set them relative to different points of your choice.
Here's how you can offset dimensions in a 2D sketch:
1. **Start Your Sketch**: Begin by creating your sketch on the desired plane or face.
2. **Draw the Rectangle**: Use the Rectangle tool to draw your rectangle in the sketch.
3. **Dimension the Rectangle**: After drawing the rectangle, select the Dimension tool.
4. **Select New Reference Points**: Instead of clicking the default points (like the corners of the rectangle), you can select other points or edges on your part as references for dimensioning. This could be edges, vertices, or other features of your part. Use references panel for this.
5. **Set the Dimensions**: Click on your new reference point and then on the line of the rectangle to set the dimension. Enter the desired value to offset your rectangle from these new points.
Once you are satisfied with the positioning and dimensions, finish the sketch.
This process allows you to have more control over the positioning of your sketch geometry relative to the existing features of your part. Remember, in Creo, the sketcher is quite flexible, and by using different reference points, you can achieve the desired offset for your dimensions.
~ CreoVerse
Michael Bourque
tbraxton
Understanding sketch references is the key to capturing design intent with sketches.
@DaveMartin  has some good videos explaining how to leverage sketch mode functionality. If you watch the video, it should explain best practice for how to handle this, if it does not then post back here with details on what is not working.
Here is one that specifically deals with sketch references.
Creo Parametric - Sketch Mode - Sketch References (youtube.com)
