Offset between annotation dimension and plane
How do I create an offset between annotation dimension and a plane?
See picture:
If I change the height of this cube, the dimension doesn't keep the offset, but disappears behind the cube.
I want these dimensions to automatically move in the same direction as the cube.
18-Opal
November 20, 2019
I don't think it's possible to have the dimension update automatically.  Once shown and then modified, the dimension will need to be moved manually.
