offset lines how do you get them to display in the drawing view ?
Hi All
I working on Creo 3  build  m120  can create  in model exploded view but will not appear in the drawing view
kai-2Answer
Please refer to the following steps.
1. Edit position
2.Click Explode Lines , Create Cosmetic Offset Line.
( To Create Cosmetic Offset Lines =>Creo Parametric Help Center )
3.Add the offset line .
4.Add 2D Drawing View
Past discussion =>Exploded View Offset Lines not showing in Drawings
kai-21-VisitorAnswer
1. Edit position
kdirth
They should show up when you set the view state to the explode state they are defined on.  Also, insure they are not on a layer or the layer is not hidden.
