Ok I give up
- August 27, 2011
- 0 replies
- 384 views
Wonder if anybody can take a look at this (empty) part and figure out why I
can't delete these three parameters.
I can change the Value, and I can (using Relations which I then delete)
convert them to a String or Real Number, I just can't delete them. For
reasons beyond my control, the part is modeled in R2001, but I have also
tried to delete them from this part using WF4.
Obviously, in the "real" part there is a lot going on (features, layout,
parameters, relations, etc), but I have whittled away on this test part
trying to get rid of these "no-longer-needed" parameters with no luck!
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
Thanks in advance,
Gavin B. Rumble, PE
Solid Engineering
336-224-2312
