3-Newcomer
Opening a file in various versions
hello!
can i work on creo 10.4 on one computer and then open the file to work on creo 10.1 and vice versa?
YES, you can work this way. But when you are working on big complicated project then it is better to use the same version on all computers.
tbraxton
Yes. All date codes of a version are compatible.
TuxedoCat3-NewcomerAuthor
3-Newcomer
Thank you!!!!
3-Newcomer
thank you for answering!!
