Opening a table pattern in excel with excel open
First, the parameter part_table_editor is set to "excel"
That said, Creo will not allow me to open and edit a table pattern in excel if I already have another excel window open.
When attempting to do that it throws this error:
The fix I have found (which is incredibly inefficient) is to close all open excel windows, open the table pattern, then reopen the excel files I am using to generate the data needed for the table pattern.
Does anyone know if there is a fix that will allow me to open table patterns in excel without closing all other excel windows?
    Here you are in the Creo Elements direct / Modeling community.
    You should better move your post to the Creo Parametric to have a better chance to get an answer.
    Ah thanks - my mistake.
    Mahesh_Sharma
    22-Sapphire I
    Hi @BrianBoman
    Article CS206558 may help.
    @Mahesh_Sharma Thank you for the reply. I discovered my browser option is set to chromium in the .sup file. As such, I wasn't able to test the alternate setting immediately. I will follow up.
