Mar 8, 2013 4:44 PM UTC
Opening Older File Iterations - Using FILE>OPEN dialog box
Hi all,
I'm stuck. I want to be able to open older CAD iterations by inputting the the information in the File>Open dialog box directly. I can't recall the correct syntax to get this to work. What I can remember, is it was formatted similar to this:
proe_file_name.prt|level=XX
Or something like that. If memory serves me, I think you can manually call up the itereation and version number. I can't recall the correct way to do this. I am working in a Windchill environment, so using "Show Instances" within the OPEN dialog box is not the solution I am looking for. Any help is appreciated.
-Adam
Mar 11, 2013 6:20 AM UTC
Hi Adam,
If you use the Windchill, do you need to Add to Workspace your old iteration from Common Space.
Note:
"Show Instances" within the ProE/Creo OPEN dialog box >> it is working only if you use ProE/Creo without Windchill.
Regards, Vladimir
