Order of BOM balloons & items BOM table
I have a very simple assembly of 4 flat sheets stacked on top of each other. The tree shows them in the correct order (bottom first -> top last). The BOM balloons however put the 2nd sheet as #1, the bottom sheet as #2, and 3&4 are correct. The BOM table correspondingly lists the 2nd layer as first in the table, then the bottom layer, then 3 and 4.
Is there a way to reorder the balloons and table?
Thanks in advance... I'm new to ProE.
Laura
Select Table->Repeat Region...
Here you can sort and change index'es for your table (the balloon ID's will follow as you reorder your table)
Hugo
The parts are usually listed in alphabetical order. If you want to change the order, you may need to add a parameter to each part. You could use this number as a "custom index number" and sort your repeat region according to this parameter.
-Matt
As mentioned by Matt, you can use an "integer" parameter and use that to automatically sort your table. I've created ours to sort as follows (shown how the table shows them):
REMOVED PARTS (PARTS DELETED VIA DRF OR FCN)
PAINT
PRIMER
Weld filler metal
"Bulk" Qty "AR" parts (oil, grease, locktite, valve packing, etc.)
Fasteners
Purchased "off the shelf" parts or assemblies (
Fabricated parts (including modified "off the shelf" parts)
Assemblies
It then has a secondary sorting as follows:
size
Description1
Dash_no
Drawing_no
Have fun.
I want the order of BOM table follow the model tree,what can I do?(I changed the location of component in the model tree,but the order of BOM table not change as the model tree)
set:
Table --> Repeat Region --> Atributes -->no duplicate/liv
