Aug 24, 2022 1:36 PM UTC
Override Section View Label
Is there a way to override the section label so that I can have two sections with the same name in the assembly. I am trying to create two separate drawings from the same model and have the sections start at A-A and go on from there.
StephenW
StephenWAnswer
Aug 24, 2022 2:08 PM UTC
@BM_8212128
There is not a really good way to do this. Things I have done in the past to solve this problem:
1. Delete the section note and add my own section note.
2. Make my second drawing use double letter sections  (Section AA-AA)
3. Make my second drawing use underscore in name (Section A_-A_)
4. Make a new assembly and the only component in the new assy is the old assy so I can make my section names
I'm sure i have used other "hacks" over the years, none are good, but I couldn't let this annoyance stop work!
StephenW
StephenW23-Emerald IIIAnswer
@BM_8212128
