Parameter Exchange
I’ve kinda got a situation here…
Consider I have two diffrent teams working in my office. One team is sitting at a different country & the other is sitting at India. Now, both of them are working on a same rocket assembly & the parameters & relations which both the teams are using are different only in terms of names.
The result/output of the parameters that are needed are same. Now, if I want to bring them together, where CREO has to identify that 2 differently named parameters are the same & it has to consider a master parameter based upon the 2 named parameters…
Is there any way to do this???
BenLoosliAnswer
You need to develop standard design and drawing templates that have a single set of parameters and use them at all design locations.
7-Bedrock
Yes, this is possible, but Creo itself does not automatically understand that two differently named parameters are semantically the same. You need a mapping strategy.
Example
Team USA
Plain Text
THRUST_FORCE = 5000
ROCKET_WEIGHT = 1200
Team India
ENGINE_THRUST = 5000
VEHICLE_MASS = 1200
1. Create Master Parameters
Define a common corporate standard:
MASTER_THRUST
MASTER_MASS
Then map the local parameters to the master parameters.
Example:
MASTER_THRUST = ENGINE_THRUST
MASTER_THRUST = THRUST_FORCE
All relations and downstream models use only the master parameter.
Now, in a very similar way consider Team USA is having the same parameters (as mentioned above under Team USA) without any values at the moment & Team India is having the same parameters (mentioned under Team India above) with certain values.
Now, I have to call them into a BOM table in an assembly drawing sheet & here I want CREO to automatically pull the parameter that matches with each other & should only show the value of the parameter which is having a certain value & exclude the parameter that doesn’t have a value. In my case it is giving me 2 columns of parameters with & without values. I only need the BOM with values & CREO should automatically identify the parameters with values !
Is there any possible way to achieve this???
BenLoosli23-Emerald IIIAnswer
