Mar 7, 2013 7:44 PM UTC
Parameter sort
Creo community,
Is it possible to change the sort order of start-part parameters while
creating a new part in Creo Parametric?
The parameters are not displayed in the order specified in the start
part.
Brad
Creo 2 M040
Mar 8, 2013 1:59 PM UTC
Brad,
You can define the sort in the rp_config.xml file, where you can also define the column widths that you want when you launch the parameter window.
Mike
Mar 8, 2013 5:02 PM UTC
Where is this file located at? I searched the creo2 install point and did not find it.
Is there a similar file for Wildfire?
Thank you,
Ben H. Loosli
USEC, INC.
Mar 8, 2013 5:15 PM UTC
When you're in the parameters you create one by doing File/Save configuration as... and rp_config.xml is the default.
Mike
Mar 8, 2013 5:30 PM UTC
Are you using PDMLink? If so, write some relations in the start part that
calls PDMLink parameters. This will automatically fill in Creo 2 parameters
and reduce the risk of user error inputs.
Example;
CAGECODE = PTC_ORGANIZATION_ID
I know of at least 5 relations that will automatically fill in Creo 2
parameters so the user doesn't have to even worry about them any more.
Lance J Lie
Information Technology
SAS IT Info. Solutions App. Eng.
Space and Airborne Systems
Raytheon Company
+1 310.616.1551 (office)
+1 310.426.4968 (cell)
+1 310.647.0315 (fax)
2000 E. El Segundo Blvd.
El Segundo, CA 90245 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
