Parameter storing value of PLM association to WTPart
HI everyone,
I'm using Creo Parametric v. 9. I would like to know if there is a way in which is possible to understand if a cad is associated to a WTPart in Windchill, in order to use it into an if statement in the part/assembly relations.
I could not find anything on this topic on the net.
Thanks in advance to anyone who can help.
Van_AG
If a CAD document is assotiated with a WTpart the CAD document contains PTC_WM_PART_NAME PTC_WM_PART_NUMBER parameters,
But!
If a CAD document was assotiated with a WTpart but is not assotiated now - for example if it was copied from another CAD document - the parameters will remain
Thank you for your reply.
Yes, I noticed that too, in fact at first I thought I could use them, but then I realized the same thing. I searched for a way to initialize them during a new copy, but I couldn't found it.
Catalina
Community Manager
Hi @AS_10932124,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Manager
