Parameters for exporting to PDF
Hello everyone,
I export my drawings to DXF, DWG and PDF alot. There are a few things I have to ckeck in the export dialog box in order for these exporting files come out like I want and I use a fews parameters in config.pro to controls the "hard set" without me have to check the export dialog box (ex: dxf_export_mapping_file, dxf_export.pro, dxf_out_stroke_text ....).
However, these parameters only work for DXF or DWG but do not work for PDF.
Has anyone know parameters for PDF, please help. For instance in the PDF export dialog box, I'd like to set the GENERAL tab as CURRENT and the CONTENT tab as NONE, STROKE ALL FONTS .....
Thank you every much in advance.
DV
I am glad you asked this question. I know you can save a profile for PDF export and I use that regularly, but there should be a way to set that profile as the default in config.pro.
Hello Dovan!
You can create a macro to export your pdf, dwg and dxf files with all the steps you want, then you don't have to do all the same things each time.
DOVANLE1-VisitorAuthor
Hello Hugo,
Thanks for response to my question. I've done any macro in Pro-e before. Do you mean mapkey? Could you be more specific (if you got time of course).
Thanks.
Sorry, my mistake, when i say macro is a mapkey. I have a macro to export pfd, igs, dwg files.
When i have some jobs that i know that will be repetitive i make always a macro. Sometimes i even assign them to a icon in proe/creo interface.
