Part decal disappears after check-in
I am using Creo 8 with PDM (windchill 12)
I am putting a decal on a part that exists in my PDM. I revised the part (rev 04) and went to view -> appearances -> edit appearance -> decal, and selected an image file from my drive.
When I look at the model and the drawing, the decal appears just fine. So I go to check in my model.
After check in and publish, I remove the part from my workspace and add it again from the commonspace.
Now when I open the part and the drawing, the decal is gone. Instead I see a grey color appearance where my decal was.
Any inputs on what is happening and how I can fix this? I need the decal to show up on my published PDF.
Thanks!
StephenW
StephenWAnswer
I think you need the config option
save_texture_with_model yes
StephenW
StephenW23-Emerald IIIAnswer
PThapar12-AmethystAuthor
Hey Stephen,
I have this config option set to yes already ! Any other suggestions?
I even tried using my image as a "texture" instead of a "decal" and I am having the same issue.
Do I need to save my image somewhere in the PDM?
Just tried this solution again, but this time I force changed save_texture_with_model to no, and then back to yes. It worked this time, amazing.
