part instance using in assembly without showing in BOM
I am using Creo Parametric 4.0 M040
1-Using a Part file from his vendor in Assembly as an instance, want to show this part is an assembly drawing only not in assembly BOM.
2- Wants to use a part file in different positions in an assembly drawing in a single view, but doesn't want to increase BOM by using the same part file for different positions.
    1. Filter by name or parameter in repeat region
    2. One method is that if you use "Make flexible" command, set a parameter to boolean, in the asm change the parameter with make flexible command on the parts you don't want in the repeat region, filter the the repeat region by that parameter.
