Part Location In Relation To Assembly?
I've created a number of assemblies with shared parts. So I have a folder for each assembly (containts ProE assembly, exported STLs, rendering scenes etc.). The setup is this format: /PART1.PRT /ASSEMBLY1/ASSEMBLY1.ASM The problem with this is that whenever I open an assembly I have to manually relocate every part by going back a directory. Is there a way to tell Pro/E the relative location of a part? I tried using Tools/Program and editing the design so for each part from this:
4dee2cac1ato this: 4dee2cac1aBut that didn't work. Does anyone know a way of achieving this? It's just some of my assemblies are quite advanced and so just opening the file is taking a while because you have to locate so many parts. Thanks for your time, Kind Regards, ScottThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
