Parts from Mold Cavity into NC assembly
  • February 14, 2017
  • 0 replies
  • 1042 views
Hello!
After finish the mold i took the two parts and design some other futures, then i create and NC assembly, I design the mill operations  (Roughing, Face etc.), > save CL File for a set (Including check the MCD File to export G-code), i choose form the PP list the machine and then i see the message  Post process fails.
- There is a specific procedure to convert the cavity and core form the mold ? I use the Mold component.
- I notice the parts for the mold they don't have visible coordinate system, why is that ?
Thank you in advance
Apostolis
