Parts not combined in BOM
Hi All,
I am experiencing a strange issue relating to parts showing in a BOM in Creo 4 M140.
I have 1 part (screw.prt) with 2 family table members. (2 lengths, screw_L1 & screw_L2).
I have Sub-Assembly A with 4 x screw_L1 and 2 x screw_L2 within and Sub-Assembly B with 2 x screw_L1 and 2 x screw_L2 within.
I have both Sub-Assembly A & Sub-Assembly B in a Master.ASM.
The Master.ASM and the screw.PRT resides in the same folder as Sub-Assembly A ,but Sub-Assembly B resides in a different folder.
Both folders are called out in the search.pro config file.
When I create a drawing of Master.ASM with BOM table. screw_L1 is listed twice, with the quantities from Sub-Assembly A and Sub-Assembly B separately, whilst screw_L2 is listed only once with the combined quantities of Sub Assembly A & B.
What I am trying to achieve is to have screw_L1 to show the combined quantity, like screw_L2 is being recorded in the BOM.
Anyone any ideas on why the BOM is recording it differently and how I may resolve this.
Thanks for any suggestions in advance.
Paul6Answer
Hi Martin,
Thanks for the offer of assistance.
However I have found the reason why, Screw_L1 appeared to be reported twice in the BOM.
It appears that in Sub-Assembly A, the generic of screw.prt was being used and reported instead of Screw_L1.
Screw_L1 was used in Sub Assembly B.
It just so happened the generic screw.prt has the same ID and part description as screw_L1 in the family table.
@Paul6 wrote:
Hi All,
if it is possible please put all Creo files into single zip file and upload zip file. I can investigate your data and give you some advice.
Paul612-AmethystAuthorAnswer
Hi Martin,
