paste Special
I have some features in one part that have inside one of them, some relations.
Now in an assembly, I copied and made the paste special, the same features to other part. after having made the advanced reference configuration, and all the features pasted to the new part, I visited the relation to the corresponding extrude, and there wasn't any relations inside.
My question is, how can i copy those features, and bring the needed relations to the other part, without losing the relations?
Hi T_F
I think what you are asking for is not possible in Creo Parametric.
in your relations there are dimensions involved. When you copy a function from  part1 to part2 with paste special, the dimensions in part2 will not have the same reference:
In my example I copied the cylinder, in part1 the radius is d16 and in part2 the radius of the cylinder pasted changed to d15...
T_F16-PearlAuthor
And do you have any suggestions about it?
I remember when I used solid works, more than 10 years ago, that there as something called smart parts, and smart assemblies, where I could have some features in memory, that when I assembled a part in an assembly I could recreate the needed features to fit the parts, like holes pockets, with just one click. I was trying to do the same with copy paste. Do you know how can I do this?
Have you looked at UDFs (User Defined Features)? That might be the functionality you're looking for. You can get feature-level relations in these. Search for "Creo UDF" at YouTube and you'll find a lot of examples and tutorials.
