Pattern of Configurable Module PTC Option Modeler Enterprise
I'm currently using a trial version of PTC Option Modeler Enterprise with Creo Parametric.
I want to create a pattern of a configurable module and select this Pattern in Variant Builder.
First, I've assigned choices by selecting the configurable module in the Pattern. Then, I've saved a Variant Spec in Variant Builder.
I can see that the model In "Model Graphics " Window is correct but when I click on "Update Assembly", nothing appears and all my configurables modules in Patterns are "Excluded".
So, Is it possible to do a Pattern of Configurable Module? How can I correctly "Assign Choices" for a Pattern of a Configurable Module?
Thank you!
Farida.
