Pattern of family-table parts
Is there a way to create an assembly of all (or certain) instances which are in a family table of a part?
For example:
1. I do have a part with a family table of all different bolts in (M8x20, M8x25, M8x30,...)
2. I create an assembly with the generic of this "family tabe"-part in the default position
3. I will make a pattern of this generic part, but not only the position of this bolt will change but also the instance
Bolt assembly.pngIs there maibe a way by doing this with a "table pattern" or in combination with a parameter which is in the part?
If this is possible, this will help us a lot!
Hi Guys,
this works perfect!
I've created the table-pattern like this:
And this is the result:
Exactly what I wanted!
Thanks a lot guys.
Dale_Rosema
Are you asking if there is a way to make a "catalog" of all the instances in the family?
Actually, we want to create "ID tags" in a family table and put them all in one assembly.
The bolts are just an example to explain it.
HamsterNL
18-Opal
October 25, 2018
What are "ID tags"?
Can you show a picture of what you are trying to accomplish?
I guess you have to generate trail file and run it to assemble family table instances.
See my attached data created in CR2 M070.
1.] I prepared bolt.prt containing 3 family table instances
2.] I prepared bolt.txt trail file containing 3 blocks for assembling 3 family table instances
3.] TEST: Launch Creo 2.0, create new empty assembly, play trail file - you will get result shown on bolt.png picture
Note: To prepare trail file for big family tables, user can create some script which gets a list of instances and generates trail file for assembling all of them.
Hi Martin,
I've tried to run the trail file.
Bolt_1 opens, but won't be placed... and there it stops.
Is there something I have to do in another way?
Thanks for your help!
what Creo version do you use ?
