Jun 23, 2018 5:19 AM UTC
Pattern table is drive using relations or parameters
Hello all !!
I do the pattern using pattern table.
Can I drive my pattern table dimension using relations or parameters ?
HamsterNL
18-Opal
Jun 25, 2018 7:33 AM UTC
As far as I know, you can't drive the table pattern dimensions directly.
But if you define multiple tables in your table pattern, you can create a relation to choose which table is to be used.
Example
Create a table pattern with two tables (called "FOUR" and "SIX").
Rename the table pattern as "TABLE_PATTERN".
You can choose which table is to be used with these relations:
IF YES
 PATTERN_TABLE:FID_TABLE_PATTERN = "FOUR"
ELSE
 PATTERN_TABLE:FID_TABLE_PATTERN = "SIX"
ENDIF
Replace "IF YES" with the actual condition you want to use.
Syntax used
PATTERN_TABLE:FID_NAME_OF_TABLE_PATTERN = "NAME_OF_TABLE"
P.s. You can also use the FeatureID of the table pattern, but using the name is more clear.
Jun 27, 2018 8:16 AM UTC
Thanks for reply..
But multiple table is useful when you have fixed value.
HamsterNL
18-Opal
Jun 27, 2018 9:17 AM UTC
That's true.
We are using a more complicated way to drive all the dimensions of a table pattern.
Excel (Step 1)
We use Excel to calculate the dimensions of the table pattern, then with a small VBA macro we create the "ptb" file which Creo uses.
A "ptb" file starts with this line:
!# Pro/TABLE
Then the rows with the information of the table pattern.
Creo (step 2)
We recorded a mapkey which replaces the existing table pattern with the one we have created in Excel. I first rename the existing table pattern, then import the new table, active the new table, then delete the old table.
Complicated as I said 🙂
Maybe this topic will help you: Regenerate pattern table vb api
