PDF drawing distortions
  • August 3, 2013
  • 4 replies
  • 1284 views
I am having a problem with Creo 1.0 - M050
When I have a completed drawing, all looks good when displayed on screen as
well as when printed. When I create a PDF of the drawing I find that lines
have moved as well parts of dimensions/notes, notes in general are re-spaced
making the drawing look poor.
Does anyone have a work around or know of a fix for this?
you try stroke all fonts option?
EdK1-VisitorAuthor
Thanks go to Wayne Falco.
He gave me a setting for the PDF Export Settings window
In the FONTS section of the CONTENT TAB, select the Stroke All Fonts.
I used it on a couple of drawings that had grown quite ugly and it fixed
them right up.
Thanks Wayne
cool beans. UR welcome
That works on the fly great.
How do you set that so it is the standard setting? Is there a config.pro value to do that?
