pdf export pen pattern Creo 8.0.5.0
The drawing must be exported as a PDF. We have phanthom and hidden lines in the drawing.
If I set the Pen 3 pattern . it will only accept one Line style.
(pen 3 thickness 0.010 cm; pattern 0.1 0.05 0.025 0.05 cm)
How could different line styles be used? Hidden line and Phanthom line both use Pen 3.
Please assist me in solving this problem.
@SP_saro wrote:
if the pattern line is removed, hidden line and the Phanthom line looks good.. but I need a different pattern for the hidden line and the phantom.
so it looks like you do not like default patterns assigned by Creo to hidden and phantom lines.
One possible solution = changing phantom component display. Please play attached video and use uploaded data.
what happens when you remove pattern 0.1 0.05 0.025 0.05 cm from pen definition.
SP_saro4-ParticipantAuthor
PDF Output
Drawing
If I can use the pen 3 thickness 0.010 cm; pattern 0.1 0.05 0.025 0.05 cm
Its shows hidden line also in phanthom line style.
once again ... remove pattern 0.1 0.05 0.025 0.05 cm from pen definition.
