PDM-Link 10.0
I have a query about PDM Link. We are on 10.0 and when I look at the information window, "where used" area for a part and then select multiple assemblies where it is used to add to my workspace, it only takes the original searched item I.E. the part in the information window?
Apparently you can select and add multiple assemblies in 10.1, is this just a bug with 10.0?
If you are on 10.0 how do you do a where used search and then check out the results?
