Apr 27, 2013 7:33 PM UTC
Pentable, pdf export
How to make diffrent colors to entites in the same group?
Letter (Blue) and crosshatch (Black)
Apr 28, 2013 12:51 AM UTC
Go to your help files and search Pen Table. You will find Example: table.pnt File. In the table entries, you can specify what color names are associated with which pens.
A full list of color names can be found under Assigning Colors to Another Pen.
Apr 28, 2013 2:12 PM UTC
2Letterletter_colorYellowThese Items Plot As Solid Lines:
§ Dimension Lines
§ Leader Lines
§ Geometric Tolerance Lines
§ All text (except Cross Section Text)
§ Balloon Notes
§ Cross-Hatching
§ Centerlines with yellow color onscreen
These Items Plot as Centerlines
§ Axes and Centerlines
I want to use another color to: Cross-Hatching
They go under letter_color right now. Can't find any information about this how to map this to a specific color
Apr 28, 2013 6:23 PM UTC
Oh, I see. If you change the color of the cross-hatch to another style, it will plot with the new lineweight.
Select the hatch, right click and click on Properties. The menu manager pops up and you want to change Line Style. use the Copy from Style and pick one of the other styles... for instance, Geometry. Apply>Done and your hatch is now the Geometry color and attributes for plotting.
Apr 29, 2013 8:46 AM UTC
Hi. Yes i now.
But my question was if i can change the group only for Cross-Hatching
Now its in pengroup: Letter_color
I want i to: edge_highlite_color
Only Cross-Hatching, not Dimension Lines, Leader Lines...
Feb 17, 2014 8:32 AM UTC
Hi. How did it go?
I have the same problem that i want another color of the hatch.
Modify all parts is not an option for me.
