Dec 20, 2011 10:33 PM UTC
PhotoLux Render Issues
Windows 7 Ultimate 64-Bit
8GB RAM
NVIDIA GT 550M
Creo Elements Pro 5.0
Every time I try to render using PhotoLUX, the result is a solid black screen. I can render using PhotoRender but the quality isn't that great.
I have tried every scene, moving floors/walls/etc, adjusting lights, adjusting effects...all with the same result.
I have tried Draft to Maximum quality. Output Full Window to JPEG to TIF...all the rendered files are solid black. It's driving me insane! I've followed as many tutorials as I can...step by step, but my result is solid black as opposed to the tutorials results of a completely rendered model.
Has anyone experienced anything like this? Have any Ideas?
Any help will be greatly appreciated!!!
Mar 22, 2012 8:00 PM UTC
Ok everyone...I finally figured it out. It was McAfee Internet Security. Not sure how it blocked it but as soon as I uninstalled McAfee, the rendering works perfectly.
Wish I knew this from the get go.
Dec 21, 2011 3:39 AM UTC
That´s weird you should check maybe your materials, i recomend to use only PhotoLUX scenes and materials (the last ones), your computer is perfect.
Dec 21, 2011 3:31 PM UTC
I went back to check all my materials...and I am using PhotoLUX visual styles and am using a PhotoLUX scene.
It's frustrating because I'm following all the instructions i can find online and it still is not working. I'll post a picture of what it looks like when I render a small section.
Dec 22, 2011 3:57 PM UTC
Floor nor walls are causing the issue...they are not in front of the model.
Also...I'm looking in Floating Modules and I don't see where there is an Advanced Render option. Should that be there?
Dec 22, 2011 6:38 PM UTC
Did some advice appear when you select PhotoLUX?
Dec 22, 2011 10:37 PM UTC
No, there was not advice. Other than it being black, PhotoLUX works fine.
BulldogFan71-VisitorAuthorAnswer
Mar 23, 2012 3:00 PM UTC
Cool man finally hehe.
