Pipe Centerlines not visible on drawing view
I am detailing a pipe and despite showing the centerlines layer, the centerlines do not appear in the drawing view.  Any ideas on why the centerlines are not visible?  Thank you.
Hi @wbottis,
Assuming your layer is being shown in your DRW and the layer status is saved, I would check out this support doc for config settings you may need to tweak (here).
Cheers,
wbottis14-AlexandriteAuthor
I just confirmed the layer is being shown and the status is saved, but no luck.  I will review the config settings.
kdirth
You may want to look at the feature properties in the model to see if the axis is on more than one layer.  I have run into this issue several times.
Also, have you used "Show Model Annotations" to show the axes in the view?  This does not require the layer to be shown.
