Piping/Cabling for automated tubing bender?
  • February 13, 2017
  • 9 replies
  • 4606 views
We are considering investing in an automated tubing bending machine for copper tubing.  From what I know we need to feed it an .STL file.  Is Piping/Cabling the software we need for this?  How does Pro Piping/Cabling relate to Creo Schematics?  They both seem like they do about the same thing.
Creo/Schematics, for piping, will give you the point-to-point piping connections of an overall system.  It will not give you tube bend data that I'm aware of.  I do believe that the piping package will give you tube bend data so that it can be added to a table in a drawing.  Whether or not you can export that out to a STL file, I'm just not sure.  Sorry, if this is not a lot of help, but the piping package is the right path.
2-Explorer
February 13, 2017
Typical bending machines take either XYZ and bend radius data or LRA and bend radius. They don't take STL. That doesn't mean that a service bureau would turn down an STL file; they would have to use it to create the correct tube bender format.
Tube Bending: From CAD to Production | Winton Machine
Piping design supports *.$$$ and *.FIF which is used by most CNC bending machines. Check whether the machine you are purchasing supported either of these two formats
Thanks, Jim
2-Explorer
February 14, 2017
I did not find any references to the $$$ format, but I did find a number of companies offering STEP, IGES, and native format model imports, such as BendPro G2V2 CNC Tube Bender Controls from Univeral Tool and Engineering.
PCX looks like an interesting product.
msteffke15-MoonstoneAuthor
Thanks for all the responses on this, its been helpful.   One more question:  Does the Piping/Cabling seat included in the Creo Engineering III license package include all functionality to export these formats mentioned above?  Or does the floating seat have more abilities?
