Placement of 3D annotation
Hey,
Is there any way to fix a 3D annotation to a specific offset from the model.. Please see picture below.
My problem is, when i change the length of the ø50 cylinder part the dimension gets hidden in the solid model. I want this dimension to follow the model, instead of just staying in its place.
So far i have not been able to find a solution to fix this, I am running Creo 10 btw!
Thanks for this.
In general I am limited on running exe files, but i see how it works, and it could might be a possibility.
But i am unsure on how this works, as the changes to my model is done with creo running in backgroud (-g:no_graphics), regenerated on the basis of a textfile and saving the model... I am not sure it is possilble to combine the run of trail file and this function.
Regarding the case with PTC support: They do unfortunately not have a solution! They said that i could submit it as a product idea and refered to a similar case: https://www.ptc.com/en/support/article/CS264008
I am not sure whether such functionality is available,. Please ask PTC Support.
Chris3
If this functionality exists, I am not aware of it.
Thanks for the replys,
Anybody then have an idea for a workaround or other good solution to this challange?
Is it possible to make a mapkey that takes the dimension and moves it xx mm in 1 direction. Remebering that i can have x numbers of dimensions i need to move, and not know the start position, so it should be on the base of the dimensions internal id that they are selceted and moved!
be brave, ask PTC Support and let us know.
Case has been submitted 🙂
Dale_Rosema
I asked about centerlines way back and received the answer that this wasn't part of the functionality:
https://community.ptc.com/t5/3D-Part-Assembly-Design/Drawing-changes/m-p/233665
