Planar bend error?
- 7 replies
- 3155 views
- Translate All
Having been trying to get creo to do a planar bend - it looks like there is an error in either the way I am doing things, or in the way Creo performs the bend:
for example
if the ID = 2080mm, then the circumference should be 6534.5mm.
If I create a flat strip 6534mm long, this should bend to an ID of 2080 with a small gap
so why when the part is bent with a radius of 1040 do i end up with an ID circumference of 6387mm? and a 147mm gap when the bend line is on the end of the part?
why is Creo making the "blank" shorter than modeled.
i have tried several bend tables, but they make no difference.
also as a side point on a creo forum why cant creo files be uploaded????
