Planes, Chamfer, Assembly
1.How to create a bisecting planes in creo?
2.What is demo mode in creo?
3.What is the difference between D*D and O*O?
4.How to understand the move in assembly, im not getting clear idea about that
Thank you,
Elango M
1. no option to create a bisecting plane directly.
3. dxd is tangent distance chamfer, oxo is an offset distance chamfer.
2. ?
4. ?
the pink curves are the offset curves.blue lines are the perpendicular line from the intersection of the pink offset curves, and then we get the above chamfer.
the offset distance is the value which we enter in the box.
