3-Newcomer
Feb 21, 2014 10:17 AM UTC
"Please confirm resetting Family Table values for given Instance to their previous values."
Someone can explain exactly when this issue appends?
What the reasons are? Which actions causes this error?
I think it can appens when different versions of family table components are in local folder and library folder...
Thanks...
Feb 4, 2016 1:19 PM UTC
We get this same error once in a while, cannot figure out why.  It eventually goes away.
18-Opal
Feb 4, 2016 2:52 PM UTC
Here is some information I found in article CS168523.  If you can't access the article, the pertinent information is as follows:
Title:
Message Please confirm resetting Family Table values for given Instance to their previous values while opening an assembly in Creo Parametric 2.0
Cause:
  • Corrupted dimension for a component placement.
  • Message logs show:
    • Invalid value: # of dimension d# (feature id #, model xxx)
    • Regeneration has been interrupted due to errors
Resolution:
  • Edit Definition of component xxx:
    • Either modify above dimension if present
    • Or just validate if properly constrained
  • Regenerate and Save the assembly
Please give this a try to see if it helps.
Another case I found in the database required the models to be sent to Tech Support, so that they could be fixed by R&D.
Amit
